RC transmiter
Dany
Hi
I'm flying radio controled aircraft models .
I thought to increase the transmited power from the transmiter
can anyone tell me how to do that?????
Dbowey
Dany posted:
<< I'm flying radio controled aircraft models .
Hi, I too, do RC planes.
Transmitter mods are not too complex, but unless you have equipment to check it
for output waveform and spurious signals, it isn'tt a good idea to do them.
There's too much potential for killing a plane on a nearby channel.
It would cost less to get a new TX anyhow. The GWS four-channel for example.
What are you using now?
Also, if range is a problem you should invest in a better receiver before you
think you need a better transmitter.
Don
Nick
I can't fathom why you need more power.
I used to fly a 10 foot RC glider to over 12,000 feet without any power
problems. Only problem I had was keeping an eye on it. At that
distance it is only a speck and usually require binoculars to see.
Rich Grise
Hi
Just hold the transmitter sideways so that the axis of the
antenna is perpendicular to line-of-sight. Maybe look up
"radiation pattern" or "cone of silence".
Good Luck!
Rich
