The motor in the BenMar draws 15 amps, but it does so thru a pair of
relays - I only need to supply relay actuating current. It is my
understanding that the ST6001 has a single pair of drive outputs which
reverse polarity, so I will need to drive the pair of relays (one for
port actuation, one for starboard) thru some diodes I guess.
I have a concern tho - since the ST6001 thinks it is directly driving
the motor, does it have any "soft start" or other such nonsense imposed
on the actuation current? This could confound my use of the output for
relay actuation.
bob
s/v Eolian
Seattle
One caution worth mentioning, I think, is that that particular Benmar drive,
if I'm reading this correctly, has huge torque capability. Setting up it's
limit switches before you first power on is worth the trouble. One Gent
called me for help after bending the rudder's tiller arm, and pulling a
couple of cable idler pulleys right off bulkheads. Some of the models had a
torque limiting jumper to adjust for the particular steering systems needs.
Old Chief Lynn
