Mark
I have a Sony Vaio GRZ660 notebook computer. It is out of warranty (more
than 2 years old.) It has 2 slots for memory chips. Both chips work fine
in 1 of the 2 slots. Recently, I have noticed that for the other slot, the
memory chip will only work sometimes. It may have been doing this since I
have owned it. I have cleaned the contacts on both the chip and in the
socket as best I can. If I press on the socket to deform it slightly before
I place the chip in the slot, the computer will boot up and show that this
chip is working. However, the next day and days after, the memory isn't
recognized. I think the socket slowly returns to its former dimensions,
which is too big for the chip.
I think that the slot is slightly bigger than the thickness of the circuit
board that makes up the memory chip, because the board feels a little loose
after it is placed in the socket..
If this is the case, what is the best solution?
1. place a thin film of solder on each contact tab (there's about 20 on each
side of the board and are close together).
2. some other solution?
Thanks in advance,
Mark
Thanks in advance,
Mark
