Bob
Raite AVPhile 715
I just got this unit for free. I was told it worked
"intermittently". I opened it up, and discovered what looks like
a computer DVD drive inside. Standard PC power connector, and
what looks like an IDE signal cable.
I checked the power supply voltages at the drive. 5V was right
on, 12 volt measured 17V. I'm guessing that would cause the
problem. Hopefully, it hasn't fried the electronics. I haven't
had a chance to try to figure out the power supply problem yet,
but because of the similarity to PC components, I wonder if this
drive might be tested in a PC. Is the signal cable really IDE
standard like it looks?
There is a zener in the power supply that had brown areas burned
into the PC board around it. Would the zener likely BE the
problem, or just an incidental effect of the problem?
Bob
Bob
