Jeff Walther
My Radius IntelliColor Display/20e starts up green, but with a strong
green that suggests having the brightness turned up way too high. The
green is like a
overall very strong wash, pretty much unusable since it's so intense.
During these periods, the focus is also out. After a period of time it
reverts to normal and is a lovely sharp monitor. That period of time
seems to be lengthening.
Sometimes, after a while, the green seems to go away, but the over-wash
and poor focus remains. Then still later the image goes back to good.
At a guess, the microcontroller that handles the settings is having some
difficulty and the monitor is starting up with some settings in their
unbiased state. Perhaps its (the microcontroller's) 5v (?) supply has
gone wonky--possibly expiring electrolytic caps? Or maybe the memory
element that stores the settings (Flash, EEPROM?) has reached the end of
its life with too many cycles?
Anyway, I'm handy with soldering tools from axial caps all the way down to
208 pin quad flat packs. What I'm not any good at is diagnostics.
I think that this monitor has an equivalent Sony model, but I'm not
certain. It's definitely a trinitron. I can just make out the two
horizontal lines at 1/3 intervals.
I hope that someone is familiar with this problem and can point me at the
likely culprit in terms of component(s) that need replacing.
Thank you for any helpful or humorous suggestions,
Jeff
green is like a
Jeff
