Darn Cat said:
what was the negative issue in the above link?
I read it with a view toward learning the reason why I don't want to
install it.
The only 'negative' that I see is that claims of saving 15% to 42% are
misleading. It can save up to 42% of the ceiling heat load on A/C. But the
ceiling heat load is <25% of the total A/C load, and the A/C load is not the
entire electric bill.
So if A/C accounts for 75% of your electric bill in the heat of the summer
months, an optimistic view would be that installing a radiant barrier will
save you 42% of 25% of 75% of your electric bill. That works out to just
under 8% of your electric bill.
Yes, radiant barriers work (when installed correctly). But some suppliers
have been accused of over-stating their performance by taking quotes from
NREL like, "Radiant barriers ... can save up to 42% of the heat load from
your attic." Sounds a lot better than it actually is (< 8%).
daestrom
