bruce
Where have other folk with a mast mounted radar scanner run the
interconnect cable? ie cable bewteen scanner & display.
cheers
bruce
cheers
bruce
bruce said:Where have other folk with a mast mounted radar scanner run the
Ideally you should run the cable inside the mast and again, ideally you
should install it while the mast is out of the boat. This would allow you to
get secure it and keep it clear of the internal halyards. (seperate topic).
The biggest problem is the connectors on the end of the cable. In my
experience, (three Furunos) the antenna end connector are the smallest and
if these connector shells are still to big to pass through access
holes/wireways, then the shells can be removed. (for the Furuno, no special
tools are requird (seperate topic, again). Once the shell is removed the
contacts on the ends of the wires should be protected, especially the small
coax cable.
The above being stated, you would of course, start from the radar display
location and work you way to the mast and then just follow the route of the
mast electrical wiring. I always feel that a mast junction box for the
radar cable should be part of the standard installation but I have never
seen one yet. I guess if you were going to pull the mast in the future, you
could disconnect at the radar scanner and pull in a chase line while pulling
the radar cable out.
The connector shells at the radar would have to be done while aloft but,
again, I found no need for special tools. Just a list of which wire goes in
which connector shell and in what location. My Furuno manual provided all
that detail.
(All the above was learned the hard way and only after I had damaged that
little coax signal wire. Your welcome to benefit from my experience.)
Steve
s/v Good Intentions
I can't see anything wrong with this or a junction box, IMHO and limitedGlenn Ashmore said:Which brings up an interesting question. Is it permissable to install a
plug and receptical at the mast partners so that you don't have to
unwire everything back to the display when you pull the mast?
