I need a good quality A3 size copy of the main receiver board schematic in
an RA7915 HF receiver. The schematic is I believe the "mark2" version of the
#2270 PCB, where R45 has been added to pin 12 of ML2. This resistor is not
present there in the "mark1" circuit.
I have an A4 size copy (of a copy, I think) but it is very hard to read due
to the high density / small size, and some component values are illegible.
Any help appreciated. Am happy to pay for expenses and postage costs.
regards,
JEFF
ZL3TNV
Christchurch, NZ.
Hello Jeff,
have a look here
http://www.vk2bv.org/museum/
If that doesn't work google "kurrajong radio museum"
Under Radio Sets
scroll down to RA7915
OK, I know that doesn't help you but others can see
what you are talking about.
I did help out Ian O'Toole with a circuit for the old
6 channel oven oscillator module a couple of years
ago. There is a good chance he may have collected
the other circuits by now. E-mail Ian and find out.
Back in the early 1970's at Racal, North Ryde, Sydney.
I used to sympathise with my workmate Bill, as he
struggled to test and repair this receiver in a small
screened room about 6 foot cubed. Inside the factory
in the height of summer, he was in an oven.
Why were they tested in a screened room? Because
the radio barely made specifications. Failed the sensitivity
specification above 8Mhz. The test sheet had to be
signed by the managing director as well as the test
technician so the receivers could go out the door not
meeting specification. I am just trying to remember
who the big fat managing director was. My memory
is letting me down. Bruce Godard! That was it!
Godard, what a good name for a big boss. Heh heh heh....
I remember my mate struggling to get a batch of these
sets out the door. Some oven oscillator modules
when plugged into the receiver, gave the Rx better
signal to noise figures than with other oscillator modules.
So the better oven oscillators were fitted to the problem
Rx's where sensitivity was a problem. That is sets with
channels above 8Mhz. Same with the main boards,
they were chosen like that also. A receiver that went
out the door with low frequency channels probably
just made specification. If higher frequency channels,
8Mhz or above, were to be fitted later, the Rx would be
struggling. These were the tricks of the test department
when one was pushed to get one's quota done.
I remember an engineer stating that all the modules
for all of a batch of six radios should be able to be
thrown up in the air and randomly selected for a
batch of six radios and they should all meet specification.
After this guy spent all day struggling in the screened
room he said to Bill, "Just do your best, Bill." and he
kept well away from then on. heh heh heh.....
You have brought back some funny memories
for me of that crazy workplace; factory romances,
good folk and arseholes. They were all there.
Regards,
John Crighton
Hornsby
PS
Hello Budgie or anyone else,
who may be familiar with an old Codan 4000 transceiver.
When I first switch the power on at the control
unit. The frequency display and LED indicators
flicker slightly, in intensity, for several seconds
in intermittant fashion and then settles down to
normal steady intensity.
I am just checking if this is a quirk of this transceiver
or not before I spend anymore time chasing this
strange behavior.
After switch on, the intensity of the display and
indicator leds vary in normal fashion. When a well lit
room darkens the the display dims as it is supposed to.
I have no previous experience of this transceiver.
Thanks for any info.
JC
