I was pointed to this link in from another post of mine regarding a
high-current adjustable power supply:
http://ludens.cl/Electron/Ps20/Ps20.html
I have all of the parts that I need and have started building a
prototype. I have a few questions before I can finish.
1) I could not find a LM336Z-5.0, but I did get a LM336Z-2.5. In the
page's notes, it says this is OK, but to change the values of R2 & R3.
For my 2.5v version, what would these two values be?
2) I am hoping to get an adjustable voltage range from 11v to 20v or
so. I would ideally like to use an 18 VAC transformer, but could not
find one locally with a high enough current rating. I figured 18 VAC
would translate into about 25 VDC after a full wave bridge and a large
filter cap. The only one I could find with high enough current is one
with a 26 VAC secondary. This makes about 40 VDC after the bridge &
filter cap. I understand it will cause the transistors to dissipate
more power, but I am mostly concerned about exceeding the operating
voltage of the 741. Is there an easy way to make this transformer work?
If I'm exceeding the supply voltage of the 741, would it work to use,
say, a 12v regulator for the 741's supply voltage? I do not have any
experience in working with op-amps.
I should expand on my application: I will be using this power supply to
charge a bank of capacitors rated at 700,000uF. This will demand A LOT
of current for a very short amount of time. I need them to charge
within a second or two, so if I use a power resistor between the supply
and the cap bank, it will have to be small. I have the transistors on
some pretty beefy heat sinks.
Regards,
Kevin Schneider
Regards,
Kevin Schneider
