I created a flyback converter. The primary side of the transformer and switching mosfet are directly connected to the rail. The rail was always 8 AA batteries, so this never went over 12V. I wanted to experiment with rechargeable options, so had a custom battery made.The rechargeable battery is Ni-Mh and when fully charged is 14.5V.
Well, this made my converter a beast! However, I noticed some jittering in my circuitry. I could smell something getting warm, and it was the 7A PTC I placed on the rail to prevent over current. I tested the current draw on it, and for the most part, it was only at 3-5A. However, there is a fraction of a second where the beast jumps to 20A. So, the PTC was clipping and causing the stutter.
The mosfet was not warm at all, and is designed for this current. So, I thought I would see what happened when I removed the PTC and jumered it with some thick copper. This ended up burning the trace between the transformer and the mosfet. This trace is .120" wide of 1.25 ounce copper, and it is in an external layer. I believe this should handle 8.5A continuous.
So, I need some opinions:
-What is happening in the difference between a 12V rail and a 14.5V rail? The capacitors on the secondary side are charging faster with a 14.5V rail. So, I assume I am drawing more current and burning things up?
-I understand that the traces are rated for about 8.5A continuous. But, there is a chance that a spike is acceptable for a brief second. Where should place the PTC value/. Under 8.5A or at it?
-Should I just say forget it and have another battery made that does not go over 12V?
