I am currently working on a project where I need to mount a computer fan into a cabinet door, but I have a couple questions about the circuitry involved.
The main idea is to have the fan get power from a wall outlet (using an appropriate adapter), and it will turn on when a computer is turned on. The signal will be delivered by using a USB cable connected to a USB port in the computer.
I have a couple cabinets that need the Single USB Build (below), and one that has two computers in it that will need a multi-USB build (also below).
My first question is: Could the single build fry the computer? My assumption is that it should work fine, though input in highly appreciated!
The second question is: Will the way I'm handling the two USBs work? Using the diodes seemed like a good plan in the beginning, but seeing the actual circuit drawn out made me less sure. Would it be better/safer to just use two relays (one for each USB)?
