Hey guys and gals. I did some google research, but didn't find what I was looking for - thought i'd go straight to the source - electronics and not auto.. Here's what i'm looking to do:
I'm going to be connecting 4 of these LED components in series: http://www.superbrightleds.com/more...s-rectangle-flexible-accent-light-module/832/ they will be the red ones - so 20mA.
I am going to connect them to a switch in my f150 - and when the switch is activated, it will go through a potentiometer, giving me the ability to dim them when I want. when the switch is off - no power.. lights out. switch on - they are on - and can be dimmed from full to zero. simple. It's an auto - so 12 V DC
Here's my questions:
1. some sites have indicated that I need a 1/4 Watt resister installed between the lights and the pot... correct? seems curious as I thought the pot is the increasing/decreasing resistor? let me know what i'm missing.
2. What "size?" "ohm" pot do I require? I ask this because I'm not sure that if I wire these up in series means that I have to add the 20mA times 4 (4 lights)? or is it just 20mA total as they are in series? either way, I'm not good with the math. What ohm pot would be sufficient. and this is the most crucial question I have as I have read that if you choose... unwisely... it could be a potential fire hazard.
3. Lastly, for added protection, I would like to add a fuse inline. I assume that inline fuse goes between the auto's power source for the lights (the 12V lighter (always on)), and the switch. please let me know if I have this wrong.
As always I appreciate all knowledge and other ideas that may work with what I'm trying to accomplish. Thanks in advance.... and this is my first post... glad to be here.
J.
J.
