E
Electronic Swear
I am now using a PTC to behave as a over current protector for
Brushless Dc Motor. However, there are some problems happened. The PTC
is connected on the
front of the main circuit ( after the main V+ ).
1) For normal operation, motor will slowly rise their internal
temperature.
As PTC is sensitive on temperature, after a long operation period (let
say 10min) the PTC will tripped off the connection. However, I do not
expect the PTC operated like this.
2) The PTC is operated as over current protector when lock rotor
happened. If i set a higher current tripped off PTC, the time for
tripped of in lock rotor protection will also increase. It is not a
good appearance for me.
So, what should I do to prevent PTC tripped off because of motor
internal temperature and also function in a short time tripped off for
lock rotor (over current) happened?
Please give me some comments on it and thanks very much.
is connected on the
temperature.
