alan
Hello,
I hope this question is not beneath the level of the EE's here, but...
Recently I have been working on a project to relocate my car's battery
to the trunk for better weight distribution. This basically involves
running a long cable thru the car up to the former battery location for
the + and a short cable from the - to some nearby chassis bolt in the
trunk. It is generally suggested to run a fuse on the + line, close to
the battery, because a short on the cable won't set the car on fire.
At some point, I asked if it was OK to put this main fuse on the - line,
between teh battery and nearby chassis bolt. The reason being the same
as why you disconnect the - terminal of the battery when you work on the
car - so that if you put a wrench between the + terminal and case,
nothing happens. I cannot believe what a sh*tstorm this raised in the
car audio forum I posted in. Several people thought that this wouldn't
work, because it was on the "wrong" cable, or that it doesn't protect
components because it is at the "end" of the circuit.
Anyway, I'm mainly asking if there is any reason that putting the fuse
on the negative side of the battery is worse than on the positive. IOW,
looking for potential failure modes. I thought of one reason why it's
better to put the fuse on the - side, as mentioned above.
