G
Gene
Good day, all.
Problem: Cause a sphere that is 6 feet in diameter and made of
0.05 inch thick plate steel (or other metal?) to reach a uniform skin
temperature
of 300F degrees by using 220 or 440VAC as a source?
First, is it possible?
(I'm sure there are better ways of doing this than making the entire
sphere a shorted heating element - but this question relates only to whether
it's POSSIBLE, not practical.)
"IF" it's possible, what type of transformer would you use?
That is, what would the OUTPUT in volts, amps, watts, etc be -
assuming that you wanted the sphere to reach a uniform skin
temperature of 300F? Basically, we just want to "short-out" the
sphere & cause it to heat to 300F with AC or DC current - so
what's the transformer design
THANKS,
Gene
temperature
THANKS,
Gene
