Hi i recently got rgb strip lights for the footwells of my truck. They run off the standard rgb IR controller ull see on amazon. They are on a relay that is controlled by my bcm (switched negative) to turn on when the trucks door opens. I fed the relays coil and common with power directly from the battery. I put the leds on a three position switch, one position the relay the other constant power. My problem is when ever the leds turn on they flash once for a milisecond before turning on. Its a small brief flash then the light stays on. The kit came with a cigarette lighter adaptor that can be used to power the rgb controller and has its own switch. I used it to test if the flash still happens when using this and it dosnt. That means the problem is sumwhere on my circuit. Yes my relay is diode protected, regardless when i eliminate the relay an only use the switch it still flashes before staying constant. Can anyone tell me how to fix this
Platforms
Content
