Question about implementing (boolean) function using multiplexer?
Hello, everyone.
I'm studying a past exam, and I'm stuck on something, but I'm thinking that the solution of the exam for the question I'm doing (Question 1 -- 3. a.k.a. Question 1 -- c.) has a (minor) error in it.
Question 1 -- 3. a.k.a. Question 1 -- c.:
https://www.docdroid.net/IeyzXy3/question-1-3-aka-question-1-c.pdf
Its provided solution:
https://www.docdroid.net/vNlE9vP/thesolution.pdf
My question:
Should the part with the (4-1) MUX drawing where there is a C be a C', instead? (I know this may seem like a small question, but I just want to make sure that I'm not misunderstanding anything.)
Any input would be greatly appreciated!
I used Logisim to verify the K-map. The output for the selection A=1, B=1, certainly seems to match C' so I believe you are correct.
Hello, everyone.
My question:
Boolean expression not fully reduced.
A'B'+ABC'+AB'D=A'B'+ABC'+B'D
because
A'B'+ABC'+AB'D =
A'B'(1+D)+ABC'+AB'D=
A'B'+A'B'D+ABC'+AB'D=
A'B'+ABC'+A'B'D+AB'D=
A'B'+ABC'+B'D(A+A')=
A'B'+ABC'+B'D
Ratch
