aerosmith said:
Hi Robert,
Thanks for the information. Can you tell me why
I might require two of the motion sensors? Does one
compliment the other or it is just for installing
it in a second location?
Neither. Those are just two different options.
NX-480 Passive Infared Motion Detector $89.00
NX-482 Sentrol Passive Infrared Motion Sensor ~$98.
Also does the RF module easily plug into the Elk M1 system?
If I were to use a wired device like a door/window contact
what kind of wire is recommended to connect the Elk system
and the contact.
There's a little cable that connects them together. Most sensors (except for fire alarm stuff) are connected using ordinary 2- or
4-conductor, 22-guage wire (aka 22/2 and 22/4). If your wire runs are exceptionally long you might use 20 guage wire but most
normal size homes are fine with 22.
Fire alarm sensors require use of cable rated for "power limited" fire alarm circuits. Most of the time 18/2 or 18/4 fire cable is
good.
Note: Even on magnetic door and window sensors which only require 2 wires I usually use 4. That way if a single conductor breaks
(say, froma staple gone awry), I've still got an extra pair.
Regards,
Robert L Bass
Bass Home Electronics
941-866-1100
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
