Hey there electronics guru's. I was wondering if someone here can help me with ...
I'm building a gate opener using a normal cordless drill as the engine.
The drill will be unmodified - it's battery will power the opening/closing of the gate - but I want to wire it into the house so I can charge the battery (eventually, I'll put in a solar panel to charge it).
Normally, to charge the battery, I would disconnect the battery from the drill and plug it into the charger.
Is it OK to just wire the battery to the charger, while still being wired to the drill, so it stays charged but still powers the drill? Or do I need to separate the battery from the drill while charging (using a relay?)
Thank you for your help
