CNDA
Ok folks,
perhaps I didn't explain myself correctly the first, so I'll try again.
Is there a way to have this machine come up on the AV1 (RGB) when
initiating the service mode. The set, a PAL Samsung
CW29M64N, will not allow me to change the source to any of the two
available AV's. The set has a RGB Shift parameter option and I'd like to
see if I can tweak it a little while viewing a test pattern from my AVIA
Test DVD. I'm trying to see if I can cut down on the loss of image (The
RGB Shift) on the set. Twenty odd pixels are cut off from the left and
around 15 pixels are missing from the top.
Thanks again,
César.
Thanks again,
César.
