Jim Flanagan
Hi..
I would appreciate collaboration from some of you who are familiar
with specifying quartz crystals. My question revolves around
the series versus parallel mode of operation.
I understand the difference between series and parallel (or so I think).
The following article makes some statements that seem to contradict what
I understand- www.crystek.com/appnotes/VCXOarticle.pdf
In the article the following statement is made:
"This is tricky and is misstated in many papers. The capacitive load is
always placed effectively in series with the crystal and never in
parallel. In other words, a so-called parallel crystal does not mean you
place a capacitor in parallel with the crystal, but in series."
Am I reading this properly? My understanding is that when when
specifying a xtal for use in the parallel mode, the crystal is
calibrated against a parallel cap. A crystal calibrated as 'series'
uses no capacitor in either a series or parallel with the xtal.
When a crystal is specified as 'series' the intent is that the crystal
frequency desired is the fs frequency, whereas a crystal specified with
a load is used in the anti-resonance mode.
The article talks about using a crystal in a VCXO circuit, where a
varactor is used in series to slightly 'pull' the motional C (Cm) to
effectively change fs.
Anyway, I am a bit confused by this article. Would anyone please share
their expertise with me? What I am doing is trying to determine how
to specify some crystals for use with in a crystal filter. I would like
to use some generic 10 MHz microprocessor crystals and am not sure
whether to buy some series or 20-30pf load caps.
I am not sure whether I have properly expressed my confusion, but in a
nutshell the article seems to indicate that the calibration is done
with a series cap. This would 'pull' the fs into the 'parallel '
frequency range. My current understanding was that the calibration
was done with a parallel cap, looking for a parallel frequency
calibration. Your help would be appreciated.
Thanks..
-jim WB5KYE
Thanks..
-jim WB5KYE
