Jason Wilder
I have a 100 mm ferrite rod on which I want to wind a coil using 0.3 mm
diameter copper wire. The goal is to detect a car passing by at three
meters. I plan to bias the coil with DC. How do I calculate the number
of windings that I have to put on the rod so that I can reliably detect
the car?
This should be easy I suppose, but I can't find anything about it. Every
book will tell you what the induced current in the car will be and that
sort of thing, but nowhere is explained how to go a bit further.
Do you have to calculate the induced current in the car and then from
there calculate the induced current in the coil? Is this back EMF? How
do you calculate that? How do you handle the ferrite rod? I am
unfortunately not very good at physics. I can think of an empirical way
to figure this out, but it will be rather time consuming.
Any help would be greatly appreciated.
Jason
the car?
Jason
