Dan
I've had a 13.8 V, 12 A Pyramid power supply for several years that
I've used with a battery charger to charge flight packs for my RC
aircraft. Part of the operation of the charger is to charge at a
given current for one minute and then drop the current to 0 A to take
a voltage reading on the pack. In the last year, the power supply has
started to shoot the voltage up to > 15 V temporarily when the charger
performs this action. The regulating circuit in the supply seems not
to be able to handle the sudden load change. The charger, which is
designed to operate with a 10-15 V source, gives an error message
regarding the input voltage and ceases to operate.
My first attempt at a fix was to have a constant load on the supply
with a power resistor across it's terminals. These became to warm,
however, and given where I charge (carpet), I don't want to use them.
Is there a simple fix to this? Maybe a capacitor across the supply
terminals to soften the sudden voltage change?
My typical charging currents would draw 2-6 A from the supply.
Thanks,
Dan
Thanks,
Dan
