PWM with a 555 Timer...
L
Len Lekx
Got a quick question.
I want to use a 555 timer chip as a pulse-width modulator, in
order to drive an R/C servomotor. The pulse width will need to be
varied between 1ms and 2ms for this application.
What I don't know how to calculate, is how the varying voltage at
Pin 5 (Control V) of the chip affects the timing. The external RC
circuit changes the timing by t=1.1RC - that much I know... but how
much does differences in ControlV alter this?
Any advice would be helpful. :)
Rob
Take a look at http://notrocketscience.mysite.wanadoo-members.co.uk/ibmport.htm
I never built it, it was only simulated but should work. From memory,
it takes a variation of around 1/3 of the supply, relative to the
positive rail to get the variation required. Only vary the voltage
between 1/3 and the full positive supply.
L
Len Lekx
Thanks. I'll keep that in mind, and look at the website later.
Oh - and just FYI... the project I have in mind *is* rocket
science. I'm planning to use the servos to drive the fins on a
vertical-stabilization system for my camera rockets.
W
WDino
Have you considered using a Picaxe-08M?
It is ideal for PWM motor control and as can be software or hardware controlled.
L
Len Lekx
Never heard of that particular device. I *have* been considering
using a Basic-Stamp... my only problem would be how to write a
non-multitasking program to vary one of the PWM outputs after a
trigger event.
L
Len Lekx
Have a look at http://www.rev-ed.co.uk/picaxe/
You would not consider using a Basic Stamp after trying one of these.
Extremely easy to use and program.
Looks to me like it's a slightly beefed-up Basic Stamp. Many of
the same commands and everything. :)
No Canadian or US distributors yet, either... according to the
website.
L
Len Lekx
I've been looking at the online manuals... it's got potential. The
'servo' command in particular would be useful - but I can't find
anything that will tell me if two servo commands for different pins
would be mutually exclusive. If I can put (say...) a 1.5ms pulse on
one pin, and a 1.95ms pulse on another at the same time. If it came
right down to it, no doubt I could use two chips - each running a
different servo channel.
Andy P
I use picaxes all the time, andthey're so relatively dirt cheap that
using two would be ideal, as long as you can tolerate the weight.
Iv'e got a question for you though...would not making a stabalisation
capacity with movable fins turn your rocket into a guided projectile,
which falls under all kinds of new rules that are quite different from
jsut a rocket that you fire and hope goes where you want it to. I have
a feeling that the FAA would not appreciate it.
