Hi all , i am working with PSoC 5LP. I have continious changable Analog Signals. I convert it to Digital with help of ADC. From this Result i want to generate PWM (Output1 Forwards, Output2 Ruckwards). All in 16-Bits. So i have range upto 65536.
I have Analog Input 0,1 to 3,3v. So if i gave Input 1,6v than i have 50% Duty Cycle of generated PWM.
PWM Basic Configuration:
16-Bit UDB
PWM Mode: Two Outputs
Period: 65535
CMP Value1: 32767 CMP Value2: 32676
CMP Type 1: Less CMP Type 2: Greater
Dead Band: Disable
Interrupt: None
Clock with 12MHz freq.
Here is the code. In ADC_Result i have 12-bit ADC result. From this result i want to generate 2 PWM Outputs. I know that i have to use WritePeriod(), WriteCompare(), WriteDeadtime() APIs.
I read the PWM datasheet & also check the Example PWM Programms but still i am much confsed for this following questions.
1. Need i Dead Band?
2. Which equation for converting ADC result into PWM?
3. Need i Interrupt/Global Interrupt ?
Regards
Max
16-Bit UDB
Period: 65535
Dead Band: Disable
Interrupt: None
Code:
int32 ADC_Result;
uint16 i=0;
int pwmValue, pulseWidth;
int main()
// Start the components
Sys_Init();
// CyGlobalIntEnable; // Uncomment this line to enable global interrupts.
// Start Clock & PWM
Clock_Start();
PWM_Start();
while(1)
pwmValue = ADC_Result // Which equation i have to use.
PWM_WritePeriod(pwmValue);
PWM_WriteCompare1();
Regards
Max
