Tony
Hello all,
All the literature I've been able to find seems to indicate that generating PWM
by natural sampling (analog input signal compared to saw or triangle wave)
produces lower distortion than uniform sampling (sample/hold the input first).
But all those same sources also use the case of "single-ended" PWM (where one
edge is fixed, and the other is modulated by the signal).
Now it seems quite logical to me that single ended uniform sampling will produce
even order distortion products, if only because the effective pulse position
varies with the signal, and natural sampling seems to partially correct this
problem.
BUT in the real world, all the natural AND uniform sampled PWM generators I have
found effectively compare the signal to the reference on both the rising and
falling edges of a triangle wave, so the pulse position does not shift with
signal. And under these conditions, it seems to me that uniform sampling should
be better.
I've googled a lot for enlightenment on this issue, but to no avail.
Can anyone set me straight?
Tony (remove the "_" to reply by email)
problem.
be better.
