Richard Rasker
Hi all,
I'm currently designing a full-bridge PWM controlled DC motor driver with a
24V/10A supply voltage. For driving each MOSFET half-bridge, I selected the
LM5106 driver IC.
As the '5106 is only available in a 20mil lead spacing MSOP, I can't do any
bench tests without designing a PCB right away, so I'd like to check up on
things to prevent costly mistakes (this is my first PWM motor driver).
Also, the datasheet (http://www.national.com/pf/LM/LM5106.html) is rather
concise.
Apparently, the high side driver derives its positive gate drive voltage via
the bootstrap capacitor. This doesn't mean that the PWM signal *must* have
a duty-cycle of less than 100% (full positive DC) for the driver to
function properly, or does it? Or does the chip contain some sort of
internal oscillator-plus-charge-pump, with the bootstrap capacitor only
necessary for storing the energy?
This is important, because I'm using a rather simple way of generating a PWM
signal with a triangle wave and an LM339 comparator(*). I don't need
precise speed control; it's only important that the motors don't start or
stop abruptly. This also means that for most of the time, the "PWM" signal
is actually a logic-level DC voltage.
Any information on this (including examples) is very welcome.
*: I'd rather use a microcrontroller-generated PWM signal -- but I'd need
six PWM outputs at least, two (both directions) for each motor. The
PIC16Fxx controllers I can program don't have this many PWM outputs, and I
calculated that it's impossible to generate even a 4-bit resolution 20kHz
PWM output in software: the program would have to check/change outputs at
20x16=320kHz; with a PIC running at 20MHz (5MHz internal clock), this would
require an interrupt rate of once per 16 clock cycles, which is not
possible.
The PIC30F2010 does have enough PWM outputs -- but my development
environmnent (both the assembler and programmer) can't handle this device.
Thanks in advance, best regards,
Richard Rasker
LM5106 driver IC.
concise.
possible.
Richard Rasker
