Hi again
@ Raven Luni: Use discrete transistors was maybe a better idea? But I'm sure it must be possible to find an OP-AMPs that can do the job at around 2 MHz. Or as I wrote, make the PWM at a lower frequency and mix it up to the signal frequency.
@ CDRIVE: I will try to explain, okay I'm better to write in Danish, so I hope you understand
The picture of signal curves:
Pulse width signal .. If you change the pulse width while keeping the same 'distance' between the positive edges in the signal, then the frequency has not changed, only the 'energy' in the signal, which is also known if you want to control a motor with PWM. Are you sending the signal through a filter, then you as a result have a varying DC voltage supplied to the engine. It is this relationship, you can also use to produce an AM signal.
You can make an AM signal in 3 basic ways:
1) The good old method right from the radio's infancy, anode / collector modulation: The modulation is applied directly to the PA stage:
Advantage: The individual stage in the transmitter need not be made linear, however, you must 'make room' for the modulation of PA stage.
Disadvantage: In order to modulate 100%, you must have an AF modulator with a power of least 50% of your signal output power. A 100 kW transmitter must have a 50 kW AF modulator (beautiful bottles with water cooling)
2) Make the whole transmitter with linear stage:
Advantages: You can modulate the transmitter with a small AF power just after the oscillator and send this 'undistorted' throughout the whole transmitter up to the antenna.
Disadvantage: All your stage in the transmitter must be completely linear, this linearity is not quite easy to achieve and is particularly critical if you send music. No problem on paper but in practice? And if you want an output power of example. 25 watts, then you must make a PA stage of at least 100 watts PEP, so there is room for all necessary sidebands.
3) AM make with PWM:
Advantage: As the entire transmitter has no AM info (all pulses have the same amplitude as a FM transmitter), then it can be made with non-linear stage also the PA stage (running close to the PEP effect). The modulation may as in the linear version (the AF signal to the comperator) may be quite small. 'The secret' is the output filter after the PA stage, this is here the PWM signal is converted into AM, just as the motor control.
Disadvantage: The PWM mechanics must done exactly correctly (risk of phase modulation PM) and must only work within the range 25% to 50% duty cycle, other% will only give 'nonsense' when we talk about AM modulation.
Concludetion: A more simple transmitter (non-linear) and a better use of the PA effect.
I hope I have explained it well enough and a understanding of why I want to do AM with PWM.
If somebody today will make a prof high-power AM transmitter, then it is also is made with PWM.
Greetings Jan
