So far I have everything I need to build my remote phosphor light except the PWM frequency generator. The current parts list consists of,
- Cree XT-E LED's
- Mean Well switching power supply
- Mean Well LDD-1500H Buck drivers
I was going to use the Storm X LED controller by CORALUX but it seems very much overkill for my application. The Storm X is used mostly for reef lighting and has a bunch of preprogramed lighting shows. I just need to dim the LDD-1500H's with a PWM frequency source. In addition it's $100 which I don't mind paying if it'll get the job done but I simply can't get a response from the manufacturer to any of my questions.
The generator needs to output 5v PWM frequency required by the drivers and have at least 8 channels of PWM output (I'm using 8 LDD-1500H drivers) and a frequency of 1kHz so the flicker isn't noticeable in video at higher shutter speeds. I only need one knob of control to control the 8 channels.
Can anyone recommend a simple 5v frequency generator with 8 or more channels that can do 1kHz?
Please understand I'm a novice in electronics. The "Adafruit 12-Channel 16-bit PWM LED Driver - SPI Interface - TLC59711" looks interesting if I were to only use it's PWM frequency generating and not the LED powering. Is that possible? https://www.adafruit.com/product/1455
- Cree XT-E LED's
