Tim Williams
I was thinking of ways to demodulate PWM (note: Google doesn't demodulate
PWM, so I haven't bothered to look for things that have done my work
already).
One method that came to mind is to charge a capacitor while the input is
high, and discharge it while the output is low. Before discharging, the
voltage is forwarded to a sample & hold for output. Since I*dt = C*dV, this
works.
But, what if frequency is changing? The above is only pulse length, not
PWM, demodulation.
One option would be to demodulate the frequency as well, as an absolute
value, and multiply the PLM output . I thought of dividing the input by
two, to get a 50% duty cycle wave, then PLM demod it to obtain a value
corresponding to duration (1/f). The value then controls the charging
current for the integrator. Response, then, will be accurate every other
cycle.
But geez that's complicated.
Does this difficulty have anything to do with the spectrum of a PWM signal?
For sure, the key information -- DC bias -- is well below the carrier and
harmonics, but purely the percent information is contained cycle-to-cycle,
so long as the frequency isn't also changing very rapidly. The usual way of
course is an LPF, but I want to think of ways avoiding that cumbersome time
constant.
Tim
already).
works.
PWM, demodulation.
cycle.
constant.
Tim
