I
Ignoramus10070
Is there a PWM chip that can properly drive an H bridge? (with dead
time, fast on and off times etc)?
thanks
i
thanks
i
Most of the DSP chips designed for motor drive that I've looked into --Ignoramus10070 said:Is there a PWM chip that can properly drive an H bridge? (with dead
thanks
i
ADI, Freescale, TI -- do this.
Dunno about discrete chips, though.
A DSP may be the most simple and inexpensive solution for your problem,Ignoramus10070 said:Thanks. You are suggesting something very interesting. I looked at
motor drive chips yesterday and was a little confused. Are they also
good for power switching applications?
Again, I am looking for some easy solution that would have frequency
and duty cycle settable, and would drive an H bridge. I can do that
either with one oscillator chip and two half bridge gate drivers, or,
possibly, with something else.
If you have a suggestion for something simple and inexpensive, it will
be greatly appreciated.
Thanks!
i
Oh, I'm stupid.Tim said:Most of the DSP chips designed for motor drive that I've looked into --
Oh, I'm stupid.
Some of the more sophisticated switching regulators provide all the
deadband & timing stuff,
and sometimes even FET switching.
There's no
reason you have to use them to actually regulate, unless you want to.
I'm trying to remember the part number, but I've seen this sort of
thing used for 4-quadrant switching amplifiers with full H bridges.
All of the smarts were analog and on the regulator controller, with
the regulator connected either directly to the FET gates or through
snubber circuits.
But there were some interesting snubber circuits, which would still be
required even with a DSP solution. Something about shoot-through, and
FETs that would scatter bits of chip package all over the lab...
Check out the HIP4080A, by Intersil. It doesn't include the oscillator,Ignoramus10070 said:I have seen several chips like that, with easily settable frequency
and duty cycle.
I have not seen one like that, and, frankly, that's exactly what I am
looking for.
So, I could find a chip that would switch IGBTs in a full bridge, and
also have settable frequency and duty cycle (using pots or some such),
I would be in heaven.
The trouble is, no one knows if there is such a chip, people say all
kinds of smart things, I spent a couple of hours looking, and did not
find anything.
If you could recall the part number, I would be eternally grateful.
Sure, no doubt about that. That's not really a problem. I am looking
for a simple gate driver solution, but snubber circuits would be
separate.
So, again, if you can recall the part #, that would be wonderful and
most appreciated.
I will be driving toshiba IGBTs. I received them (4 on a heatsink)
last night. I was already able to drive them with a wavetek 171, and
see them conduct current when turned ON and not conduct when turned
off. I watched wavetek's on my oscilloscope and it was a fun evening.
i
and duty cycle.
looking for.
The actual FET / IGBT gate driver ( and level shifter ) is typically a separate
IC from the control chip.
Probably can't be done well in one package due to different processes required I
expect.
but it has everything else including programmable dead time on the top
and bottom FETs. You could use anything from a 555 on up for the
oscillator (and if you're clever about where you put the PNP you can
even get a linear ramp from a 555).
Tim Wescott wrote...
I'm fond of the HIP4080A and HIP4081A parts. Intersil has app notes
showing how to implement a PWM controller from the '4080, using its
comparator, but I prefer the '4081 with an external PWM generator.
For example, with a phase-shift PWM modulator for the H-bridge FETs.
Ignoramus10070 said:I see. That's unfortunate, but looks like it's the reality that I can
deal with.
I like IR21094 as a gate driver, and also MAX038 as the signal
generator. Both are DIP based. The only issue that I see, for now
(which may not be a big deal) is that MAX038 produces +- 1 volt, and
IR21094 needs 5 or so volts to turn the bridge sides on and off. So I
need to amplify MAX038's output a little bit. That can probably be
done with an appropriate transistor or some such.
So, I would use MAX038 driving two IR21094 gate drivers.
MAX038 has its frequency and duty cycle separately settable with pots.
Does this plan make sense to you?
I don't understand why you want to use a Max038.
The MAX038 is a high-frequency, precision function generator producing accurate, high-frequency
triangle, sawtooth, sine, square, and pulse waveforms with a minimum of external components. The
output frequency can be controlled over a frequency range of 0.1Hz to 20MHz
Why not use a classic PWM controller ?
expect.
Pooh, I found a very simple chip XR2206, it is not perfect because
duty cycle and frequency are not independently selected, but it is
simple.
Ignoramus, this is about the time you'd better start telling us
what it is that you're trying to accomplish, because as the
thread wears on you're getting more and more off track.
If your problem falls into the typical range of PWM applications
(motor/solenoid control or power conversion) there is a host of
good PWM control chips out there, and the XR2206 isn't one of
them.
Ignoramus10070 said:Pooh, I found a very simple chip XR2206, it is not perfect because
simple.
