In this circuit:
http://kitsrus.com/projects/k48.pdf
Why is the other end of RV1 grounded?
Thanks,
Michael
yeah, like everybody says, and you're on the right track with your
input impedance idea; tacking the far end to ground stabilizes the
input impedance so that the input signal is well behaved with respect
to where you set the pot at. on the other hand, if you just had a
variable resistor in series, like with the thing ungrounded, the input
signal source seeing a wildly changing impedance both in value and in
reactivity (from mostly resistance to mostly capacitative) will very
likely change its frequency response etc, unless it's nicely designed
to ignore that kind of thing.
