I have a engine start button with three connections
1. Ground -> connected to car's negative battery terminal
2. Positive -> connected to car's positive battery terminal (fused)
3. Output -> when pushed provides a positive output
The harness I'm tapping into has multiple wires:
1. ACC - Accessory
2. IGN - Ignition
3. STR - Starter
I need to wire in relay(s) so that when the key is put into:
ACC - accessory items are functional
IGN - and the button is pressed, power to accessory is cut until the button is no longer pressed.
STR - Obviously the starter wire will need to be cut to prevent the key from starting the car. The person is forced to use the push start button.
The accessory wire will need to be cut as well and each end connected to a relay (i'm assuming).
Here's a vehicle diagram depicting the vehicles ignition harness and how the turn of the key affects each.
The car requires the key to start, but my goal is to leave the key in IGN and then use the push start to crank the engine.
1. ACC - Accessory
2. IGN - Ignition
3. STR - Starter
