W
Will
I have never heard of Peter Belt but he has some unusual ideas.
http://www.belt.demon.co.uk/newsletter/vol0602/vol0602.html
Below is an extract of his newsletter. Is he a well-known crank or
something like that?
------------------------ END QUOTE -------------------
If you have a CRT TV or plasma screen, you can improve it's picture
by attaching a strip of the purple material with Sellotape at the
extreme edge of the screen. Be pleasantly surprised. Apply a strip of
the purple material along the length of the TV, satellite and radio
co-axial cable to hear and see obvious improvements. Further
startling improvements can be had by wrapping a strip of purple
material on the co-axial plug of aerials and it's adapters. If you
own a portable and it has a telescopic aerial, wrap around the purple
strip at the base of the diameter of the aerial. Interconnectly, I
use a lot of Kimber cable PBJ stuff. Be amazed when you wrap a purple
strip on the collar of the phono plug exiting from your CD player.
The effect seemed to be more obvious when this is done at source. If
one treats both sides of the interconnects, the effect is
accumulative. Again, one could apply a purple strip along the length
of the interconnect to good effect. The fuse in the main plug can be
treated too. Wrap around the purple bit in the centre of the fuse
with Sellotape. I say wrap around as I have already tried lengthwise
with no effect. Remember to fit a purple strip to all your main
plugs. All your batteries benefit too. Wrap around the battery with a
purple strip. Trust me, I have tried and tested all these months,
they work. Give it a go. By the way, the purple strips respond well
if they are attached to CD jewel cases and vinyl from covers. Further
to this, audio cassettes and video cassettes respond to a strip of
purple attached. As a final reminder, the purple crucifix should be
attached to CDs, DVDs and vinyl discs for maximum effect
