Pulse transformers
sanjoealex
Can anyone tell me where i can get good but simple information about
pulse transformers,its analysis also(pulse response...).Thank you.
Robert Baer
The major difference between an ordinary transformer an a pulse
transformer has to do withhow it is wound.
One method used is bifilar windings, another method is to use coax
cable, using the shield for one winding and the center conductor for the
other (and yes, turn sratios *can* be different than 1:1 for coax cable
windings).
SolarWind
Many different types of pulse transformers in market, that depends on
pulse width, frequency, power, impedance, voltage step up or down,
turns and turn ratio..., I suggest you to search in web, just type
"pulse transformer" or "pulse coil" and you will get hundred of them.
