L
L.A.T.
I have now got a picaxe chip to turn on and off a camera infrared remote and
so activate the shutter of the Canon G2 at regular intervals. (Thanks David,
thanks Phil)
Simple enough, if a little messy and tedious.
But I am getting a little more ambitious. It is obvious that I can discard
the I.R. remote control and drive an I.R. LED directly from the picaxe, if I
could find out what is the sequence of pulses that the camera is expecting.
The picaxe has an inbuilt set of I.R. codes, all of which I have tried, to
no avail.
The picaxe can also send single pulses, and I believe this is the way to go.
Find out what is required, write some little loops, and fit the 8-pin
picaxe, a couple of resistors and an infrared led and a couple of batteries
into a Dick Smith switched battery case.
It all comes back to knowing what pulses to send.
Canon is hopeless. Their websites are hopeless, and if you finally get
through to a human being, they are hopeless.
I guess they wouldn't disclose the information anyway. It might cost them a
$19.95 sale or two.
But there has to be a way to find out what the hand-held I.R. device is
sending.
Any suggestions?
I have a few computers available, and an old CRO.
I wonder if there is some way to remove the IR LED in the hand-held, and
send the output to a sound card and look at the input some way.
Someone out there has the answer, and it might well be one of you guys.
I hope so.
thanks Phil)
no avail.
$19.95 sale or two.
sending.
Any suggestions?
I hope so.
