I started last night on my own Pulse oximetry circuit. I managed to get a red led to dim very slightly in response to my heart beat measured through my finger. The LED dipped very slightly in brightness. Quite an emotional moment!
I used a KIA358p, an infra-red photo diode from a mouse and an infra-red LED I had bought for another project plus also the red LED. The OP amp was set to make a gain of 20. I had a 3*AA supply to the infra red LED and another 3*AA supply to the OP Amp. It worked..
I am a new bee to electronics and I wonder if you guys could help.
1. Why did I need to use 2 power supplies. If I tried to power the OP amp using the same supply that lit the infra red LED, it would not work.
2. How can I get a better reaction in the red LED. On Off to each beat, rather than a slight Dimming.
I can post the schematic after later, after work if that would help? Once I get this to work, I intend to connect the circuit to a Picaxe to then count the beats and produce a BMP rate.
JPU
JPU
