Hi - as you can probably already tell I am not an electronics expert! i can just about hold a soldering iron.
I have a problem and hope someone might be able to help me with a circuit design or at least give me pointers so I can research and learn myself.
My problem:
I need to remove the tachograph from my vehicle as I no longer need it. It is provided a pulse signal where the frequency is relative to speed from a hall effect sensor on the gearbox output shaft.
I have identified from some minor wiring revision after removing the tachograph that once provided with a 12v power source the output from the hall sensor can be directly routed to the vehicles ECU and provides a suitable signal for the ECU to drive the speedometer, odometer and the like.
So far so good - however the speed displayed is exactly 10x the speed the vehicle is moving at (based on GPS reported speed).
What I think I need:
I think I need a circuit that can take the pulse feed form the hall sensor and output a pulse feed that is 1/10th the frequency of the input feed but with the same wave form??
Is this possible?
My problem:
Is this possible?
