I need to selectively pull a 7Vrms AC Signal to 0V, using the output of a
comparator. It comes through 4.7k.
If it were DC I'd use a VN10LP N-Channel Enhancement-Mode MOSFET but that
conducts -ve voltage even when it's switched off so has problems with AC.
I've come up with a circuit involving two VN10s and diodes to ensure they
only act in one direction but I'm sure there must be more elegant way.
The supplies I have are +/- 18V and +5V.
I've also considered using an analogue switch.
I'm sure that there's a simpler way to do this, perhaps a N-Channel and a
P-Channel fet in parallel. (It would require that each doesn't conduct in
its reverse direction, which the VN10 does.)
Could somebody suggest something? Part names would be very handy
Thanks for any help.
