Hi. What I would like to do is install a pull down 1.5kohm resistor between a/c voltage source )from a variable reluctance sensor that is 2-10v with 25v spikes) And the ground plane of a 12v automotive system. The question is whether the AC voltage to the ground will harm other electronics that are grounded to that same plane. I am trying to limit the voltage input to the ecu.
