Hi all, I've been asked by a friend to see if i can repair his pug mill, looking at the wiring of the switch i can see a blue (neutral) wire hanging free. Looking at the switch box and the wires i'm not confident it is robust, I don't like the floating terminal block. I've attached photo's so you can all see and advise if i just need to reinsert the neutral wire in it's appropriate terminal or if i need to get a new switch and get rid of the floating terminal block? If it's reinserting the neutral wire i'm unsure where it should go. The owner of the pug mill knows not to switch it back on
Or if this job is for a qualified repairer i can advise that also
Thanks in advance
Thanks in advance
