Mark said:
I own a pub and am currently spending a fortune on replacing blown bulbs
varying from 40W spots to normal 60W bulbs and also energy savers too. They
seem to blow at random thoughout the pub (which has 3 separate circuit
boards) and the wiring seems old. Any ideas as to why they blow so often?
You could be particularly close to the lv transformer on a leg which has
a lot of recent load increases further out - and they have put your
voltage to the upper limit to compensate. Or large loads have gone and
they haven't reduced the voltage to compensate. You can ask the local
distribution company if this is the case - I have found them very honest
and reasonable to deal with.
You could be buying the cheapest imported lamps. Like with anything
else, you get what you pay for. Energy saver types usually come with
some form of minimum life warranty and the supplier should "happily"
take them back and provide replacements.
Old wiring should not affect lamp life - but may shorten yours.
Lamps normally fail on switch on - so, if you must switch them on and
off, use a dimmer switch.
Vibration will kill cheap lamps to - so, try to minimise it. If you
can't, fit the lamps intended for it - they cost more but will last a
lot longer.
Really dangerous and probably not applying is if the springs on the
light fightings have got tired and the telescopic connectors are not
making a good enough contact with the lamps. This can be very bad for
business.
You can get long-life incandescent lamps which will indeed last a long
time. However, they give out less light and/or use more power and the
extra cost in electrickery is usually more than the cost of the extra
numbers of replacements needed.
