PT100 RTD Lead resistance compensation
Hello
I am using PT100 RTD to monitor temperature in my product.
PT100 Sensors will have a lead resistance which will give rise to offset error..
This needs to be compensated.
Do PT100 sensor manufacturer provide this compensation in the cable or should I provide it by using a wheatstone bridge?
If bridge is to be use then how should i go about it?
pls help me...
Regards
Mayuri
1) No, the manufacturers do not and can not provide a compensation because they do not know the length of the cable and therefore the resistance.
2) Yes, you will have to provide the compensation.
3) No, a wheatstone bridge is not the right way for compensating the lead resistance.
There are several methods for using PT100: 2-wire, 3-wire or 4-wire.
Compensation requires 3- wire or 4-wire topologies. I recommend one of those.
Here is an application presentation.
And here is some comprehensive theory on the PT100s.
Harald
