Hi!
Quite new to this so please forgive me if I'm not wording things correctly etc!
I have a computer power supply. It's not ATX but reasonably similar I think. It's from a small IBM AS/400 model 150 computer. The PSU model is IBM Part# 40H7561 made be Delta Electronics and carries a Delta Part# DPS-250CB A. If I google the DPS part number I get images that don't really look like this PSU!
I have two of these computers. One works perfectly, the other does not. I've changed components around between the two computers and the problem definitely follows the PSU.
There's a small LCD display panel and associated circuitry that should come on as soon as mains electricity is provided. I'm pretty sure this is powered by the +5V line on the PSU. Once that powers up, it is then possible to switch on the computer properly.
The problem is that the panel isn't properly powering up. The LCD is faint and none of the panel buttons do anything. Sometimes, I can cajole the computer into switching on. When it does, it all works fine except for the front panel. It remains dark. So this is my thinking as to how I've isolated the problem to the 5V line.
I do however see 5V on the aux line on the PSU. If I short the Power on to GND, the PSU fires up properly and I see correct voltages on the other lines (12V, 5V, -5V etc).
There's two capacitors near where the 5V line connects. I've removed and tested them and they show good uF readings as far as I can tell.
As I say, if I switch the PSU out for another one, it all works just fine.
Is it possible that the 5V line isn't providing enough power? What can I do to check and fix this?
cheers!
fog
cheers!
fog
