I have worked on a couple of Protons. Sounds like the same model.
They squel when they have a short and that seems to usually be a
shorted HOT. That is usually caused by bad connections in the H drive
circuit.
Also had opens in the SMPS. Simply open, bad, oxidized solder that was
a better insulator than,,,,,,,,, you get what I mean.
Did you do a physical inspection yet ? I am gonna tellya right now, it
will be VERY VERY difficult to get service info on that, I never had
it even when they were new.
IIRC, check the HOT, if shorted run the traces back to the H drive
Xfmr. Most likely. The jungle IC is not a very advanced design, but it
has some enhancements. It may have been an LA7644 but it needs to be
exactly the right type. Like a Sharp, in some cases.
Inspect ALL circuit boards, especially the SMPS. You might be able to
get it running without the print.
JURB
