I am having a very peculiar problem with my Proton 320 hi-fi clock radio. It all started happening after I took apart the unit and reassembled it. I have taken apart dozens of electronic products before and reassembled with success, no lingering issues. My reason for opening up this unit was to examine the burned out bulb for the tuning dial (which turned out to be a wired grain of wheat bulb).
After I reassembled the radio, I checked the functions and everything worked just fine. I turned off the radio and left the room. A few minutes later, I heard the radio was on. Thinking I imagined turning it off, I shut it off yet again. And once again, it turned back on after a few minutes.
My assumption was that maybe somehow something didn't assemble properly. I unplugged the unit and disassembled it again. Nothing appeared to be out of the ordinary. I took a look at the switches and they do not appear to be fully mechanical. They are spring loaded, but the engagement is "soft". I'm thinking they must be microprocessor controlled. Anyway, I used an air compressor to blow out any debris that might be inside them. I reassembled the casing and plugged in the unit. This time, the radio came on immediately. I pressed the off switch again, and the radio came back on again within about 5 seconds--much faster than before. And repeat pressing of the buttons ended up resulting in the unit not staying off for more than a fraction of a second.
So, the condition got even worse. Is this a bad on-switch, or a faulty processor? I've never seen this kind of problem before and searching on the Proton 320 does not turn up any other reports of this problem.
Any advice on what I should check? Thanks!
