Ivan,
I was wondering what part you didn't understand about making
variations. You are right, here are the formal steps that I use
when working from an existing land pattern.
1) Make a new component. Cancel the land pattern wizard as
soon as it comes up.
2) Rename the blank component to your desired name. Tools,
Rename.
3) Go to the original part. Copy, ctrl C, remember to click
your origin point after the ctrl C (this is a silly Protel
gotcha, no click, no copy).
4) Go to the new blank part, click in the work area. Paste,
crtl V. Click on the origin point (assuming that is where you
clicked when copying the original).
5) Then edit the original part copy through regular cut and
paste routines. Be sure to renumber the pads added or copied as
needed to ensure correct numbering.
6) When editing the part I will usually use group copies or
deletes to just make the edits that much faster and easier,
especially if you have many pads or weird grid patterns.
7) When finished be sure to save the additions. File, Save.
Good luck.
Sincerely,
Brad Velander
Ivan said:
Brad,
I hope I haven't wasted too much of your time. I learned through the
help files how to copy component. I apologize for any inconvenience I
may have caused....
Your guidance has been very helpful to me.
Ivan
