Protel DXP and Copper Fills
Costas Vlachos
I'm using Protel DXP for PCB design (fully manual routing), and I often need
to fill large areas with copper (grounding, high current paths, etc.). Is
there a way to tell the s/w to fill an *arbitrary* closed outline with
copper (other than the polygon plane tool)? What I usually do is just fill
the area with overlapping thick tracks until it's covered completely. Is
this how it's done? Any smarter/easier way to do it?
Thanks.
Costas
_________________________________________________
Costas Vlachos Email: [email protected]
SPAM-TRAPPED: Please remove "-X-" before replying
Peter Bennett
That's what the "Place Polygon plane" tool is for!!
When you place a polygon plane, you can draw an arbitrary outline,
connect the plane to a net, and Protel will fill the polygon,
carefully avoiding any other nets within the area.
Costas Vlachos
Thanks Peter. Yes, I know about the polygon plane tool. It's just that I
don't normally use nets and just lay the board manually (no auto-routing, no
schematic, no net list). I simply use the s/w as a drawing tool. All of my
objects are assigned "No Net". So, when I use the polygon plane, it "avoids"
everything, even pads that should be connected to it. What I want is
something like "Place Fill" but for arbitrary outlines. I'll try to assign
some nets where necessary and give it another go.
cheers,
Costas
