PROTEL 2004 - BUS Multiply
cora7_s@yahoo.com
Could anyone let me know a valid syntax using "REPEAT" keyword to
multiply a Bus in a multi channel schematic design (PROTEL 2004)?
A "REPEAT (BUS [1..4])" Entry Sheet in Parent will not make
vertical connection with a BUS[1..4] Port on Child Sheet. It generates
errors.
Brad Velander
Cora_7,
I had previously seen your post to the PEDA listserver. I am
not sure that anybody understands what you are trying to do. If
you didn't get an answer on the PEDA list then you are in
uncharted territory or you have defined your problem in a manner
that others don't understand.
Are you just drawing a schematic or are you doing some VHDL,
SPICE or other detailed code type input? A schematic on it's own
doesn't have a repeat function, other than the good ole fashioned
copy and paste. So I think you have people lost and wondering
what you are doing.
Just by what you have written below, I would say that you
just drop the "REPEAT", do away with the brackets and your bus
would connect fine between sheets, just make sure that the
netlist generator has the desired net and port configuration for
your design hierarchy. Don't know where you got the "REPEAT"
from.
cora7_s@yahoo.com
Thanks for feed-back Brad.
I'm back with some extra details for you guys:
I drawing just schematic ( no VHDL, no Spice), but using multi channel
design concept. The whole idea is to nest and repeat an entire sheet in
other in order to simplify schematic and also PCB design. Concept
it's come exactly to avoid multiple copy -paste.
Take a look to "True Multi-channel Design" Bookmark on
http://www.altium.com/learningguides/dxp/dxp_featurehighlights.pdf
Altium provide a simple example describe on TU0112 Creating a
Multi-channel Design but it don't show syntax to repeat an entire
bus. Let suppose in this example that I need Bus P[1..8] and/or
K[1..8] link out the sheet (Bank.SchDoc ) via a Port and get repeated
four times in Parent sheet ( Detector.SchDoc ). What syntax I should
have for correspondent Sheet Entry of REPEAT(PD,1,8) Sheet Symbol?
By the way, If I try to compile this multi channel design example,
witch come with PROTEL 2004, I get following errors: Duplicate Net
Names Bus Slice K[1..8], Duplicate Net Names Bus Slice P[1..8], Wire
Net Label OFF at 420,610 placed on a bus.
I don't understand why.
Brad said:
Cora_7,
what you are doing.
from.
Sincerely,
Brad Velander
errors.
Brad Velander
Cora,
So I see you are using DXP, well I am not so you have me at a
disadvantage but I went to the link you supplied to see what you
were seeing.
This "instantiation" issue is certainly new to DXP, I have
never heard the term used before. However, reading the
description they supply I think I have a good idea of what they
are doing. Usually in the past we drew one schematic of the
daughter sheet and it had multiple iterations linked through
multiple sheetsymbols on the parent sheet. Seems this new system
uses only one sheetsymbol on the parent sheet with this "Repeat
keyword" you are trying to define. Then each daughter sheet gets
X number of tabs, one for each repetition of the circuit.
Ok, this is not so different than the good ole system only
the schematic appears in one sheet instead of X number of virtual
sheets below the parent. Then the one singular sheet has tabs to
switch designators appropriately for each circuit repetition.
That is my take on it anyway, new spit and polish for the old
system. It is all fluff!
As far as I can see the key word is a function that is built
into the sheetsymbol on the parent schematic sheet. I would think
that there is a keyword "Repeat" accessible for a sheetsymbol. Or
you must add the keyword into the sheetsymbol some how.
As for the ports, your original question, I don't think they
are special in any particular way. Port AD[0..8] on the daughter
sheet connects to port AD[0..8] on the parent sheet. There is
nothing special about the port naming from what I can see, use
the same conventions as one has always use for ports and
sheetsymbols. The repeat seems to come from the Sheetsymbol and
adding (or setting) the Repeat keyword for the sheetsymbol.
I did some checking on the DXP website, lo and behold I found the
following tutorial for multi-channel designs:
http://www.altium.com/learningguides/dxp/tu_dxpmultichannels.pdf
Check page 3, points 3, 4, 5 & 6. I was right it is a keyword of
the sheetsymbol.
Sincerely,
Brad Velander
Brad said:
Cora_7,
what you are doing.
from.
Sincerely,
Brad Velander
keyword
to
It
generates
Similar threads
F
Replies
6
Views
2K
f knoff
F
Replies
3
Views
2K
bill.sloman@ieee.org
F
Replies
13
Views
2K
Jon Elson
I
Replies
0
Views
1K
I
I
Replies
1
Views
2K
