Hello,
Please help me to solve the next problem.
I want to heat a bread oven controlled by a static relay, a triac. When one of power resistances make short circuit. current growth and triac is destroyed.
Even if a protection circuit stops the command to static relay, it still remains open until the first pass of tension through 0.
If the current exceeds in 10 milliseconds more the surge current ,I MM, static relay is destroyed.
So I believe that the introduction of inductances in series as the best solution to retard the growth of current for 10 milliseconds.
I do not know to calculate the inductance section and number of turns for conductor, if using E + I transformer
Solid state relays has IMM 1200A surge current 10 ms
Working current is 50A
